Merge edge/join edge grasshopper
Hi! When i do brep offset i get small edges on a new brep. Is it possible to execute join edge command in grasshopper?
I have seen a similar topic but it was a long time ago, and and without an answer. Brep.JoinEdges command in Rhino to grasshopper
use Flexibility plugin and Brep merge Edges Component and Brep split edge Component.
thank you!
Instead of posting code and geometry of your own, it doesn’t work for me to post a link to a seven year old thread where no code and geometry was also not posted :bangbang: :frowning:
3. Attach minimal versions of all the relevant files
As far as I know, there is no such thing as brep offset in standard GH :question: :man_facepalming:
for example:
Merge Edge.gh (10.0 KB)
https://developer.rhino3d.com/api/rhinocommon/rhino.geometry.collections.brepedgelist/mergealledges
https://developer.rhino3d.com/api/rhinocommon/rhino.geometry.collections.brepedgelist/mergeedge
private void RunScript(
	Brep brep,
	int index,
	double tol,
	ref object Brep,
	ref object numberofmerge,
	ref object domain)
        Component.Name="BrepMergeEdgeAt index";
        Component.NickName="Merge Edge";
     int count=0;
    var ag=Rhino.RhinoDoc.ActiveDoc.ModelAngleToleranceDegrees;
    if(brep!=null){domain= brep.Edges[index].Domain;
    if(Component.Params.Input[2].VolatileDataCount!=0)
    ag=tol;
     if(Component.Params.Input[1].VolatileDataCount==0)
    count=brep.Edges.MergeAllEdges(ag);
    else
   count= brep.Edges.MergeEdge(index,ag);
      brep.SetTolerancesBoxesAndFlags(true, true, false, false, false, false, false, false);
    brep.Compact();
numberofmerge=count;
Brep=brep;
and for Split.Brep.Edge
	Brep brep,
	int index,
	List<double> parameter,
	ref object berpSplit,
	ref object NumberOfSplits,
	ref object domain)
        Component.Name="BrepSplitEdgeAt P";
        Component.NickName="SplitEdge";
        if(brep!=null){
int count = brep.Edges.SplitEdgeAtParameters(index,parameter);
  if (count > 0)
    brep.Compact();
berpSplit=brep;
NumberOfSplits=count;
Hi Joseph. In this case it’s more of a conceptual question rather then a some specific case I need to solve. So I just wanted to know if it’s even a thing in the first place. Offset brep is just an example, I bet you can get splitted edges in a different way.
Yes, there is no such thing in standard grasshopper as offset brep, but I don’t think this forum is exclusively about vanilla grasshopper. In real job there are plenty of cases where you have to be quick, and will not spend a week trying to avoid plug-ins because of some strage niche principles. I am sure this thread will be useful for someone. Have a good one!
Without any example, this thread is absolutely useless.
