I am using Rhino 5 64 bit. Looking at the bottom of the screen where it shows usage, minutes from last save and such I see. Memory use 609 MB and then available physical memory 13781 MB.
I have looked in vain as to where I can change the amount of physical memory used to no avail. Back in the old days this was done in the operating system files but I can’t seem to find anywhere to make these changes. Any help would be most appreciated.
If you mean 'how much memory can I allocate to Rhino?" it’s now all automatic as far as I know. Also, since you have 16GB of RAM along with a 64-bit OS and Rhino, you should have more than enough … unless you open 100 gigantic Photoshop files. If that’s the case, then don’t open those 100 Photoshop files.
Dave,
Thank you for your quick reply. I have been having no problems mostly just wondering if there was a place to change these settings. Now that I know its automatic I see why the memory usage changes as I do my work.
