Point cloud deviation from surface
Sir, i have surface and point cloud and i need to measure the deviation between the surface and cloud , overlap to common reference so that the deviation reduce.this is the surface and point cloud. thank you surface deviation from point cloud.3dm (90.1 KB)
Make a copy of the surface and locate it so it is aligned with the point cloud. Then use PointDeviation to check the deviation between the point cloud and the surface.
interesting point could version, I wonder if I could get anywhere with it on one of my projects :thinking:
