bip
June 30, 2019, 5:11pm
1
Is it possible to measure/calculate force/gravity in Kangaroo?
Have a look through this thread:
The deformation in this example is extremely small. As you’d expect - a 40m long, 10mm diameter steel cable hanging under only its self weight stretches such a tiny amount it isn’t visible (less than 0.2mm over the whole cable), and for most practical purposes the result would probably be considered identical to the standard grasshopper catenary component (which also has it’s own tiny errors, due to the way it is discretized).
If you change the Young’s modulus to, say, 2e+7, to make it a m…
You can also check out Cecilie’s K2Engineering plugin which builds on Kangaroo to add more tools for reading reactions and stresses
bip
June 30, 2019, 5:36pm
3
thanks very much, appreciate it
bip
July 1, 2019, 3:51am
4
Hello Dan,
just wanted to go we you and your fellow support contributors a shout-out for providing immeasurable help and assistance to wannabe designers lost in the deep sea of the mystery of software functionality.
