MCP for GH/Rhino/Rhino.Inside
Runaround
I rode a live Rhino in — Phenome Link 0.23.0
Whiskey. Something for the positronic lobes, I’ve been in the saddle since Tuesday.
You want to know how it handles. It’s not a machine, friend. One mind, one thing at a time, and every so often it plants its feet and won’t budge till somebody dismisses a dialog. You don’t automate an animal. You ride it — and all the engineering is in the tack.
The tack is what I came to sell. A plugin talking HTTP on loopback, another watching for the moments the beast stops answering, an MCP server making reins of the pair. Rules of the trail, and I hold to them because a canvas has no compiler to hold me: one group, one job. A group wears its signature at its edges and nothing crosses otherwise. Colour is a role, not a hatband. review says where I fell short. I never set a thing down by hand.
What you’d notice from the porch: it lays the canvas out for me — groups as blocks, the flow running left to right, every comment landing on the thing it explains — and laying the same definition out twice gives the same picture twice. It reads a canvas back as a diagram, so I can see a definition I didn’t build without squinting at a screenshot. And it doesn’t lie to me: it never calls a thing failed that quietly went through. That’s the one that costs you two of everything, and it nearly threw me.
Want the tack? Unblock both files (Properties → Unblock), drop the .gha and .rhp in your Grasshopper Components folder, restart Rhino. .vsix for VS Code. Rhino 8, Windows.
Fair warning, since I’d want it: it’s early. Loopback, no lock on the door — don’t ride it on a shared machine. One UI thread, so slow is slow for everybody. And it won’t make a poor rider good. It’ll make a good one honest.
Download: GitHub - theObjectCo/Phenome · GitHub
Now. That whiskey.
A couple updates posted. Changelog here:
0.24.2
  • Open documents can be listed and switched between
  • Closing takes two verbs: close discards, saveandclose writes first
  • Wires stop showing a selection nothing could clear
  • A group reports the signature you declared before anything is wired to it
  • The first verb after launch no longer fails with “There is no document”
0.24.1
  • Pair with VS Code registers the server for every host, not only Claude Code
  • The notes no longer send you to restart a session that was never the problem
  • The HTTP fallback says how to start a session
0.24.0
  • A refused place names every entry it could not resolve, not just the first
  • An ambiguous component name comes back as something to paste
  • preview takes a single object or a list, not only a group
  • set with param:"preview" points at the verb that does it
  • The pairing notes carry each component’s ComponentGuid
0.23.0
  • A verb reported as failed no longer turns out to have run
  • A client that disappears is no longer logged as a broken verb
  • One agent’s long verb no longer locks the other out
  • A Scribble’s text is no longer silently dropped
  • arrange is idempotent
  • New objects land in free space instead of on the origin
  • Notes can be read back, with their position and box
  • arrange places notes as captions
  • Notes appear in the mermaid diagram
  • group plants declared ports on a group that already exists
  • The command-line echo is bracketed and carries the whole address
  • A release carries the plugin files rather than a Yak package
0.22.0
  • An agent’s edit marks the document modified
  • The command-line echo reads as columns and carries the port
  • escape cancels whatever Rhino is waiting for
  • camera reads or aims the active viewport
  • plugins says what is loaded and where it came from
  • sessions with use and release pins one canvas
  • console?mine=true returns the link’s own lines
  • Saving through the link no longer leaves the window saying “unnamed”
  • A group at the end of a definition reports its outlets
  • Data mapping takes effect
  • arrange stopped reporting a settled layout as moved
  • Rhino can be closed through the link
  • pulse reports clickable from the Rhino plugin too
  • dismiss honours key in the Rhino plugin
  • Two Rhinos at once stopped losing entries and clashing on ports
  • bake says why it did nothing
  • describe reports runtime messages, enabled and drawing
  • place rolls back what it added when a later step fails
  • Leftover port files and stale autosaves are swept at startup
Phenome Link 0.33.0, and a security fix that affects every earlier version
Every version up to and including 0.31.0 answers requests from a web page. A page open in a browser on the same machine can post to 127.0.0.1, and one of the verbs the link answers compiles and runs C# inside Rhino. Reaching the port from another machine was never necessary. Opening a tab was enough. Anyone on 0.31.0 or older should update.
0.32.0 refuses anything carrying a browser’s headers, checks Host, and requires Content-Type: application/json on every POST. That last check is the one a page cannot get past, since asking for JSON provokes a preflight the link declines to answer. Install the .gha, the .rhp and the .vsix from the same release: an older extension does not send that header, and the new plugin refuses it.
Two changes since 0.24.1 need action. The MCP tools are now mcp__phenome__*, so Pair with VS Code has to be run again or the host finds no tools at all. And dismiss is superseded by dialog, which refuses to guess which button means yes, since on a save prompt that guess writes or discards a file.
Smaller things landed too. plugins reports the plug-ins Rhino has a record of and never loaded, which is the usual answer to a plug-in that will not appear. restart brings up a fresh Rhino, the only way a rebuilt assembly reaches one. The extension has also stopped guessing which Rhino to talk to when several are open, and it draws the canvas and the viewport in two panels that are worth having over a VS Code tunnel.
The link still binds loopback with no authentication. Any program running on that machine can drive it, and 0.32.0 did not change that.
