Maybe a bug latest update rhino 5 - colour change
Hi, today I received a new update of Rhino 5 which I quickly installed.
I noticed almost immediately a problem that affects the colors that are assigned to objects.
If I assign a different color (properties) to an object (polysurface) part of a layer and then I detach it from this, instantly the object back in the original color of the layer.
It also happens to someone else? Maybe a bug?
Paolo
Hi Paolo- I am not sure I follow the steps, quite, but
  • I make a box, and assign a display color to it that is different from the layer color.
  • I ExtractSrf a face from the box.
  • The extracted face is the same color as the rest of the box- are you saying that in your case the extracted face is layer colored?
Thank you Pascal, I try today and the problem is gone.
I think that when the system is overload there is some problem.
Sorry, I worried too quickly.
Best regards
