hello, team,
how can I avoid this problem?
or when will this problem be solved?
Again?
Your definition is hitting one of the limitations of ShapeDiver. You can read more about this here:
https://support.shapediver.com/hc/en-us/articles/360020300692-Model-checking
https://support.shapediver.com/hc/en-us/articles/360009130740-Limitations-regarding-definition-outputs
I also had a recent discussion with another use in the forum about this topic:
Most likely, you need to reduce the size of your display geometry. Make sure everything is meshed in Grasshopper and decimate the meshes if needed. You don’t need detailed geometry for display, only for 3D printing.
We have covered the ShapeDiver geometry limitations and how to optimize in this video tutorial: https://youtu.be/K45_Z_gB6YU
