Materials in Rhino are not showing texture
I am wondering why the material texture isn’t showing even when I have assigned the material to these tiles. Instead, it just seems to use a color that basically describes the material.
Attached is my file as well.
Thanks in advance
For Help Rhino.3dm (771.5 KB)
I’m seeing texture here- it’s subtle but there-
help>check for updates to get the latest rhino
Yes, I see texture in the material panel but not on the tiles that I applied those materials to. I was expecting the texture to be quite noticeable in the rendered view as I have seen in some previous posts… I will check the updates to see if that helps.
Thanks
Ok, I have updated Rhino and it still isn’t showing the materials properly. Added some corten steel to make sure that it wasn’t just the wood textures that were not showing up.
If you (or anybody) has any more suggestions it would be greatly appreciated.
Thanks
For Help Rhino.3dm (1.5 MB)
run systeminfo command in rhino and post results please-
Rhino 7 SR7 2021-6-9 (Rhino 7, 7.7.21160.05001, Git hash:master @ d2161989109d5dacba531310b5d345ce6f4da9f6)
License type: Educational, build 2021-06-09
License details: Stand-Alone
Windows 10.0.19042 SR0.0 or greater (Physical RAM: 12Gb)
Primary display: Intel(R) UHD Graphics 630 (Intel) Memory: 1GB, Driver date: 3-30-2021 (M-D-Y).
Primary OpenGL: NVIDIA GeForce GTX 1050 Ti (NVidia) Memory: 4GB, Driver date: 4-23-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 466.27
> Integrated accelerated graphics device with 1 adapter port(s)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 4-23-2021
Driver Version: 27.21.14.6627
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Program Files\AsuniCAD\Bubble 3.0 WIP28\RHINO7\Bubble.rhp “Bubble”
C:\Users\Brendan\AppData\Roaming\McNeel\Rhinoceros\6.0\Plug-ins\Fologram for Rhino (468a328b-20d9-494b-b9e1-cbe9f827d3a2)\2020.2.1.2\6\Fologram.IO.Rhino3d.Win.rhp “Fologram for Rhino” 2020.2.1.2
C:\Users\Brendan\AppData\Local\Programs\Enscape\Bin64\Enscape.Rhino7.Plugin.dll “Enscape.Rhino7.Plugin” 0.0.20335.757
C:\Users\Brendan\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\EleFront\4.2.2\ElefrontProperties.rhp “ElefrontProperties” 1.0.0.0
C:\Users\Brendan\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\SubstanceImporter\2.0.1\Substance.Win.rhp “SubstanceImporter” 2.0.1.0
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.7.21160.5001
C:\Program Files\Rhino 7\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 7\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 7\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.7.21160.5001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.7.21160.5001
C:\Program Files\Rhino 7\Plug-ins\Alerter.rhp “Alerter”
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.7.21160.5001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.7.21160.5001
I’m curious if you temporarily disable bubble, enscape, fologram, elefront, and substance
if the preview returns to normal-
if so, turn them on one at a time and restart between each to see which plug in is causing the issue.
my guess is enscape, but it’s a worthy experiment to go through.
Ok, I will try that out - thanks
Got it - Thanks again
which plug was causing the issue? that way we can chat with their devs to see if we can fix it-
Well, tbh, I feel like an idiot as I tested out all the plugins and they seemed to work. I believe that the problem was related to the scale of the drawings and not that the texture wasn’t actually there. I was working in meters and those tiles were 200m tall and therefore the woodgrain was not noticable even decently zoomed in.
