I have 20 walls and I want to add a material for each wall different from the other, do I have to do new types to achieve this thing
The same question, but if I want to change the thickening of the wall, should I do a new type as well?
This is tired and boring
You have to edit any wall then change any thing like material… thickness… Etc.
all walls in the same style
Hi @jon-vrin,
I’m happy to announce that VisualARQ 2.6 will support per-wall layer thickness, just like slabs already support that. Moreover, we also added bottom and top per-layer offset, which allows different height per wall layer (one of the most demanded features):
Unfortunately, it is still not possible to change the layer material per wall instance.
Why do you need to change the material of a layer on each wall?
Enric
I only just saw this post. Is this the first step to make floor - wall intersections in the future (structural layer of floor connect to structural layer of wall)?
