Hello, my material previews are so dark. When I move the view with the right mouse button, they are brighter (plastic is then white), but then become dark again a second later. The example shows standard materials, I have not changed anything in the materials. The details also seem to disappear.
The details seem to disappear because most likely the unit size for the detail is 1000mm. Right-click on the thumbnail in the materials editor, go to thumbnails and then properties. In the dialog presented set 100 or 50 units.
Further in Rendering panel under color adjustment make sure gamma is enabled and set to 2.20
Thank you very much! It has helped!
