Material component error in RIR v 1.12.8407.24005 or above
Hi everyone,
is there anyone has the same issue of using the material components?
I have create a loadable family and defined the materials… however, the cut pattern and shaded colour is not appearing in the project.
I am using Revit 2023 and RIR v1.12.8407.24005
I have also uploaded the GH definition here. If you have the same issue, I think this is the bug from the daily update…
20230117_createFamily_Material_Issue_forum.gh (86.1 KB)
Thank you in advance.
I’ll dig into this, but If you loaded the family into the project and then went back to the family to change material properties then the project material won’t be updated. The Family/Project materials have different Element ID’s. You would need to alter the project material. Is that what’s going on?
Hi @Japhy ,
thanks for the answer.
This script create the family and add the family in the revit documentation.
Cut pattern must have been inherited from the project file… Therefore, the hatches should appear correctly in the .rvt file.
the same script used to work RIR v 1.5 but it seems not work with the current daily updates.
Thanks for your help.
Yeah, something looks broken on the Material Graphics component . Thanks for reporting.
Hi @park,
Now v1.13 contains a fix for this problem.
Next Tuesday we will release a hot fix for v1.11 and v1.12.
