When I want to change a material’s color (say to green, for example), I click “OK” and the color changes to dark grey, every time. Repeating the process results in applying the correct color, but it’s an annoying little bug.
BETA
(6.0.17311.8431, 11/7/2017)
Beta
Windows 10 Pro
AMD Firepro W7100
Hi Brent - hm…it looks like your process here is to select/clock on the layer material swatch, change the color and exit that material editor, correct? Does it work to change the object material (i.e. material set to Object and not Layer)
We need a file and instructions to get it to happen here.
If we can, it may be a problem in the file.
If we can’t, it’s related to something unique to your setup.
Part is shown as being dark grey. If I repeat 2 through 6, the part turns
he correct color. I have a backup computer running the same version of the
software, and the error is exactly the same. It’s a slightly older AMD
video card.
I’ve assigned this to Steve Baer. He’s one of the developers that’s working on the display pipeline stuff. Hopefully he’ll have an idea or other things to try to get it figured out.
