materialIssue 001.3dm (6.6 MB)
I have a Rhino file that has two layers:
- anodesplitters that has a copper coloured metallic material applied to it, the layer contains a cylinder.
- magnets that has a cycles emissive colour material, the layer contains a group containing rings
Here are the rings and tube in raytraced view
If I apply the copper metal texture to the magnets layer then the copper material base color becomes black (not copper).
Steps taken to see the problem.
- click on the material circle for the magnets layer on the layers tab
You should see this:
- Select Copper from the dropdown.
Note the color is copper colored.
- OK the dialog
This is what you see (I expect the rings to be a copper coloured metal:
The base colour of the copper texture has become black:
Obviously, this is a bug. ![]()
Version 7 SR5
(7.5.21100.3001, 2021-04-10)
Commercial
