@qmalletdu The new TestSubDEdgeMatchCommand in Rhino 8 WIP should be able to help you match the boundary of the SubD to either the curve or to the NURBS cylinder you are describing. The test command supports position and tangency continuity. Check out this other post for more info
TestSubDEdgeMatch: A new command to match SubDs to other Rhino objects .
