how to match the orientation/angles of one group to another (match blue to aqua)?
match orientation-7.3dm (71.9 KB)
not getting expected result with Orient…
Following the prompts,
I select points 1 and 2 of aqua obj
followed by points 1 and 2 of blue obj
expected the aqua obj to be mapped onto the blue one
(tried Orient3pt as well)
I just tried it here using the Cen osnap, and as expected the aqua object (1), now is superimposed over the blue one (2).
What are you getting and what are you expecting?
Your result is what I expected. The process as I understand:
You have both cylinders selected.
Only select the one you want to re-orient.
If you pre-select before starting the command, only select the magenta cylinder.
If no objects are selected when you start the command, then select only the magenta cylinder, and then continue into the command.
