Hi, I have a set of trimmed and untrimmed surfaces I need to apply a pattern to as if they were a single entity and considering their normals.
Upon mapping the pattern it results in individual behaviors for each surface. Things I’ve tried:
-MergeSrf on Rhino (doesn’t work with trimmed surfs)
-Brep join in GH (no effect resulting from this)
Any advise is extremely useful as I haven’t seen any conversation on this topic which seems to be essential.
So I mirror 2 times your structure, join it, cap it (to be solid) then I made a centered square drape above. The apply the Kangaroo script then the mesh result is transformed in surface and you could apply the pattern you want. 0081Mesh_drape_quad.gh (218.6 KB)
Thank you. This is extremely close to the perfect solution, I just need to tweak the undercut created at the edges. I have a problem with the plug-in Kangaroo components V1 which is nowhere to be found, I assume that’s the reason I can’t change or even find the Gravity component. Do you reckon it has any impact?
It’s simply that by opening the file the application keeps asking for the information on the attached screenshot. I assume it’s OK to just ignore it.
I’ll keep working with this and let you know if any issues. Thank you very much!
Laurent, in order to resolve the undercut created by the draped surface (attached screenshot) I extended the bottom of the Brep. However, upon replacing the old with this new Brep nothing happens to the subsequent elements. Is there anything in particular that’s missing?
I’m also confused by this. I tried to open your file, and get the following, despite having downloaded the thing from the food4rhino link (which seems to be an older version of what’s already included with Rhino these days?):
However, now that I downloaded the similarly named thing from that site, I do see the hexagons (which I didn’t see before… but the error messages remain).
