Hello, thanks to the Add TopoSolid component of Rhino Inside Revit, it is possible to generate TopoSolids in Revit from a mesh in Rhinoceros. However, if the mesh representing the topography has an overhang, the result in Revit will be incorrect. Is there a way to handle overhangs in Revit when generating a TopoSolid from Grasshopper?
Can we create Voids and Joined Elements using nodes of Rhino inside Revit for TopoSolid ? I had a look and I don’t really get the impression.It seems that the management of TopoSolid creation with RhinoInsideRevit is quite limited ?
There aren’t RiR components assigning voids/joins and such, which are typically one off operations. There are scripted versions of join elements on the forum.
