Making technical drawings per Element
Hello Hello,
I’m working on a script to automatically create prefab wood framing elements. The elements will be made by “hand” with simple wood woking tools, so no fancy CNC machines.
Currently working on a way to automatically create technical drawings of all the individual elements at once. Using make2D… I’m having problems with creating individuals views, is there a way to accomplice this?
if needed I can share a GH file.
Cheers!
I would lay the panels flat in a gh script and add dimensions there. In Rhino 7 this is best done with Elefront, in Rhino 8 you can also do that with native tools.
As always, sharing a file is a magnitude more useful than (only) an image
