In the process of developing a base topography model, I have imported 3ds max files as fbx.
I’ve found that the imported mesh is various parts of various resolutions, sort of connecting, but not really.
I’m looking for a more expedient way of combining these parts into a single coherent mesh, while preserving the detailed features scattered throughout.
So far I’ve run through (with no success):
(rhino):
drape
quadremesh
subd (without curves)
vertices alignment >> face normal
meshrepair
fillholes
(zbrush):
Zremesher
Dynamesh
Hello - if you Join the meshes and then run matchMeshEdge - you may need to adjust the distance, depending on the scale there - you should be able to match up the vertices at the edges - but it may look messy at the seams. It may also be worth testing out the QuadRemesher in the V7/WIP.
