Hello everyone, I have a question to ask. I am quite new to grasshopper and Rhino, I have constructed a shaft using the functions such as move, extrude, lines and so on. But the question is how do i turn it into a closed volume body. I will the grasshopper file below if anyone would like to take a look at it. And I will also attach a photo of it.
Initially the plan was to divide the shaft into sections. thats why there are sections like that, I just did them using series and move function. Is it incorrect? If it is incorrect, what would you sugggest me to use to make this shaft into sections? Thanks!
When you say sections…do you mean like A or B? Because your GH looks like B - your shaft is divided into smaller sections and each of those sections is divided like a pie - this is what you’re after?
I wanted to ask something else about the same subject. For example for each segment it has the arc length of L,L,L and one of the arc to have L/2. Because it would act as a fitting to close off the segment as in real situation, we are unable to close off the segment perfectly. I will attach a photo below, if it helps you to imagine what I’m talking about. Im sorry for these questions, I’m still trying to learn this powerful software and there seems to be alot of ways to do one thing. Thank you for your help!
Yeah it wasnt mentioned above, but I’m trying to look into it right now. Experimenting with split brep. I tried changing the counter to 4 and I think the result is quite the same.
It helped me a little bit since the part is already divided. But thank you very much for helping out! I’m going to do some trial and error to see if there’s any way to do it.
