Creating pipework looking structure within a volume
Hi!
I am looking into ways of creating a pipework looking like geometry that is controlled by a simple volume referenced from Rhino. The best I could come up with was to create smaller voxels, randomly reduce their count ( to not have so much of a grid looking system) and then simply pipe the edges.
It does not, however, give me that exact thing i am looking to create. Maybe there a way to perhaps have certain criteria for how a poly line can be drawn within the volume (like always turn 90 degrees, min max length of the segment)? Or any other suggestions on how to approach this?
I have attached my script and the image of the resulted geometry. The pink and grey render image is kind of what I am trying to achieve.
Thank you!
pipework within a volume.gh (75.5 KB)
Hi!
Not the fastest, but might get you going if you adapt to your script:
you’ll need mesh pipe component if you don’t have it
test of piping on one of the units (using mesh pipes as they’re faster)
volumes_voids_pipes_help01.gh (44.1 KB)
[edit] alternatively you might want to ‘wrap’ your breps with a different logic like what Michael does here:
Hi @René_Corella!
Thank you for your response. Will give it a go.
I have a suspicion that #pufferfish can somehow be used to achieve the desired result as well.
As an indication/fun only … try the attached as well (works on a cubic like grid minus [an user option if voids > 0] random origin voids [of size vx,vy,vz]).
Recursion_NodeInGridConnections_V1.gh (130.3 KB)
It works (using recursion) solely dealing with indices thus is real-time fast (2ms or so) if you opt for the connection axis:
Time grows (10-20 ms) is you opt for pipes using poly segments as rails. No fillet option is implemented nor you can use the whole polyline as a pipe rail (VERY slow results in both cases for good reason).
Watch what the info panel has to say: there’s no guarantee that each polyline can have the maxNodes (since the directions of grow MAY are blocked by the previous ones).
Very nice! Thanks!
BTW: The start of each poly is on some (randomly picked out of the 6) out side of the initial grid. But if the - optional - voids consume all the side pts … then there’s no start and nothing comes out. In fact several checks of that type must been implemented in order to achive(?) some(?) results(?) in any situation … but that was made just as an entry level Recursion demo for the people in the practice. Recursion is a freaky coding approach where a Method calls itself (LOL) until something right (cross fingers) happens and this paranoid loop terminates.
This means … er … hmm … that a red C# is not out of question (far from it).
Thus the usage of the whole thing is just for fun. Anyway I’ve added 2 “safety” checks more (out of a zillion required):
Recursion_NodeInGridConnections_V1A.gh (128.5 KB)
BTW: rollTheBones just re-executes the C# … meaning another random result
Second picture looks like pufferfish‘s discrete polyline
Added an autoZoom option (rather handy I guess) and a classic Indexing Tree (poly Nodes indexing, that is [requires ~ a millisecond more, but no pain no gain]):
Recursion_NodeInGridConnections_V1B.gh (129.1 KB)
Ohh! Thank you all!
