Hello, i’m working on a Project that requires two Pipes to cross each other. The vertical Pipe needs to be cut at the intersection of the Pipes. I used Split Brep to Filter out the Intersecting but i dont know how to remove it. Unfortunately im to far into the Project to remove the Pipe and make two out of it one for the top and one for the bottom part.
Thank you very much for all the effort. Probably a dumb Question but how can i edit stuff in the Rhino Window? I can only change it in the Grasshopper Window.
This is what i have right now for this middle section. The two strands are for the inner and outer Pipe. How can i remove the marked section ( Fig.1) without having the hole in the middle. The horizontal Pipe should be continuous.
I hope this will be useful. I can’t use “Trim Solid” because i have trimmed surfaces and I don’t know how to change that. Maybe I went the Wrong way from the very beginning.
To create the tube there is a Pufferfish component that creates a solid with the desired thickness starting from a surface.
To avoid interference in the joining of the surfaces it is necessary to rotate the tube 90 degrees.
