Make2D Silhouette per Object - Workaround with Rhino/ Grasshopper
I searched for this option for a long time. Silhouette per Object. I now wrote a Script, that uses the RH6 Make2D with hidden lines and grouped. As I’m writing I think it can even be simplified.
As seen in the Screenshot hit “grouped” and “hidden lines”.
Next reference the grouped elements into grasshopper curve component.
Make2DOutlineEachBuilding.gh (19.4 KB)
The script uses a VB Script component from David Stasiuk (Closed Curve Intersection Network - Grasshopper)
I hope this is helpful.
Thank you! have been searching for this exact output
Hi, looks great!
I have a Issue with the human component (see pic below), because Iam using Rhino7. Do you have an alternative way to get the silhouette without these component?
Thanks!
