Make2D missing curves
Continuing the discussion from Make 2D drawing:
Looks like the current WIP is still missing a few curves in the model that was uploaded in the thread above. The bottom of the cup curves upwards to the center and should be a hidden line as such. The top edge of the cup is rounded and a single surface and that is also causing problems. Might not be so easy to fix…
Thanks Vim. I notice that some tangent line and hidden lines were not shown up in the 2D drawing. I maybe check with Rhino support team:)
It’s @GregArden who works on the Make2D code and he reads the posts here on Discourse.
This is tricky case. Although improved in V6, there are still a couple locations that have problem.
I filed a bug for it. Thanks for sharing.
http://mcneel.myjetbrains.com/youtrack/issue/RH-33624
