Is there a way to pick the default colors for the Visible and Hidden layers created when using the Make2D command?
Thanks,
Dennis
Thanks,
Dennis
I don’t think you can set them, but…
You can set the resulting layers to match the ones of the objects you have selected before/during Make2D.
Yes that’s true. But it’s just one more step which could be prevented by having it preset in a template. Hear that McNeel guys? Add it to you list for nest time!
Thanks
Dennis
You can always use scripts and make the output closer to what you want
You could probably setup the Make2D layers with your preferred settings and save those to a template file. That way they exist as you want them when you make use of them with Make2D
How does Make2D know to use my layers and not create its own?
The controls are in the Options section of the Make2D command dialog.
