Can anyone advise me regarding a Make2D error/ issue I seem to be getting?
I’ve got 2 files each with 2 objects I’m running Make2D on. They’re all relatively simple objects and nicely aligned in a rectangular fashion. But, in one file where Make2D functions just great, the other file (attached here) I’m getting an error where the object looks like it’s bent or skewed - though it doesn’t happen in the other two views.
As you can see in the view below the perspective (in both files), it looks an s though the foreground and background ends of the tubes I’ve drawn are offset from each other - skewed.
To double check my drawing competency, I drew some vertical lines off of 2 CPlanes and everything in 3D lines up. So, it doesn’t look like I’ve skewed the 3D object while building.
I read that Make2D is a bit finicky and I’m not sure if it’s just a case of repositioning my perspective view or if there’s just a better view to start with other than something that looks about right in “Perspective”. But, another file with objects just as simple turned out just great, and I’m not sure what I’ve missed if anything.
Make2D setting also attached.
Cheers
Make2D Error.3dm (1.3 MB)
