after aving some issues while making a drawing I tried to test the Make Round Hole on a single planar surface.
It seems I can only make one hole…
Here is the sequence from the command window:
Command: _RoundHole
Select target surface
Center point ( Diameter=3 DrillPointAngle=90 Through=Yes Direction=SrfNormal )
Center point ( Diameter=3 DrillPointAngle=90 Through=Yes Undo Direction=SrfNormal )
Center point ( Diameter=3 DrillPointAngle=90 Through=Yes Undo Direction=SrfNormal ): DrillPointAngle
DrillPointAngle <90>: 180
Center point ( Diameter=3 DrillPointAngle=180 Through=Yes Undo Direction=SrfNormal )
The first command after the Select surface does work. But then I cannot make any more hole on my surface. On a polysurface I can chain the hole before I press the enter.
Now If I press Enter and start the sequence for the second time I can make a second hole
But after that I can no longer make any new hole.
Normal?
