I wonder if there is a way to do this or maybe can we consider it for the near future?
I don’t really know how Blocks are managed in other CAD software, but having two set of layers for each block is quite annoying (The layers of the geometry inside the block + the layer the actual block object/instance resides on).
Not only in terms of geometry organization but also when working.
I use colors often to make sure things are in the correct layers. Often my instances end up all over the place because they just have the colors of the geometry inside the instance, but not of the layer they currently are.
Basically there is no visual way to tell on which layer a Block instance is…
I would like my block instances to get colors from their current layer, and yes, if a block has many layers, the instance can naturally only have one, so this means the entire block will display with a single color.
Being able to have a switch for this would be nice. The same way we can switch between display by layer, by color, etc.
