The new UI for Usertext in Rh6 is great.
But it would be even better if it had its own tab so that I can see an object’s Name and Usertext at once.
Now I always have to click to swap the UI display.
Or is there a way I can do this already?
HI -
I’ve looked through the YouTrack items but couldn’t find an earlier request for this.
I do get what you mean, though. On Layouts, I find myself constantly switching between the UserText panel and the Detail properties.
It might not be limited to the UserText panel, though.
So the properties tab shows the properties of “something” and the various sub-property icons at the top of the tab contents all show a sub-grouping of assorted properties of the same “something” that the main property tab shows.
It seems like it makes considerable sense for the identifying info (ie: type, name, layer) to be dis[played “above” the sub-icons and stay with the properties tab while the sub-property panels are shown “below” the sub-icons. The sub-panels needn’t repeat the identity info.
I think I would find this arrangement more satisfying than the current one.
@wim here is a YOUTRACK issue that addresses the same problem:
https://mcneel.myjetbrains.com/youtrack/issue/RH-39315#u=1494831427088
here is another request for this:
And here it is in my discussion with @Trav. I believe he originally implement the UI for Usertext:
Hi -
Thanks for finding that! I’ve added this thread to that report.
I’m not so sure about that. Most users (we don’t collect statistics so my guess is as good as yours) don’t name their objects. Layer information for the selected object is always visible in the status bar.
You are, of course, absolutely right about that, but the main point was that the ID info, such as it is, that is now shown on the object tab should instead reside on the properties tab and stay there no matter which of the sub-property tabs is currently showing.
And my guess (mostly from observing posts here on discourse) is “more than you might think”. Anyone who is working on projects with a lot of objects eventually figures out that naming objects - at least the important ones that get a lot of action or look a lot like one another - helps a lot when selecting, etc.
Many users apparently find naming so helpful that they have written scripts or plugins to do automatic naming for them.
Type and layer can be very useful in many situations even when there is no name, although the improvements in filtering have made a big difference too. It’s just the difference between having the info available at a glance or having to make some clicks or button presses to find out what you need to know.
A few questions for yourself as well as @Goswin
Are there any sub panels other than Attribute User Text that need access to those properties? EG do the Material / Displacement / Curve Piping panels need access to Object Name?
Beyond Object Name and Object Layer what other object attributes would you suggest be persistent?
I have pondered the addition of a 2 way binding text field operator in the Attribute User Text panel that would give you the ability to not only see the Object Name but also be able to change the Object Name by setting the value in this field. The 2 way binding fields get a little more complex on things like Layer Name were a misspelling or predefined list selection needs to be adhered to but I think it could work if we constrain the UI properly.
My fear here is that by loading every possible panel and option, 3rd party plugins included, into a persistent state the performance during object selections could be severely impacted as most of those panels don’t do any computations until they are the active panels. The other issue is the sheer size of the panel UI and the scrolling nightmare that it could become trying to find something.
My posts were directed at the “common factors” of a hierarchy of tabs. Much like an equation with a common factor which can be pulled out or the idea of inheritance in OOP, I’m suggesting that information that is (or should be, based on frequent tab switching to find it where it is) common to the sub-tabs should be placed on the main tab and remain visible while a sub-tab is selected and displaying it’s unique information.
As I mentioned earlier I think the type should be part of the properties display in addition to name and layer.
I defer to Goswin on the other aspects as I have never had a reason to need Usertext.
Thanks @Trav for looking into this.
I can think of several ways to solve this, here with increasing complexity:
I think the simplest solution would be to just give the user text its own tab, collapsed or hidden by default.
Give every nested window under properties its own tab, collapsed or hidden by default:
These Icons could even stay her under properties, but clicking on them would open the respective new tab.
Here is a nice example of why Usertext makes Rhino so useful. These guys even build their own user text viewer and user text tools:
video here
@Trav I spoke with @scottd and @andy about this at the Pub in London yesterday. So many people are using these user text key values to turn Rhino into a BIM software. I works well actually! Just really a shame that I cannot see layer name , object name, und user text properties at the same time. Always have to click back and forth.
@Goswin, funny @andy pinged me while you were there together. Technically there’s not much stopping us from placing this dialog into its own static panel, in fact, depending on your programming skills you can spool this panel up in your own user interface. At some point during Rhino 7 I moved the panel’s core code and UI into RhinoCommon, because of this you can access this panel, though be warned it hasn’t been designed for a good 3rd party developer experience (but that could be tuned up easily).
We can also implement something for Rhino but we’ll need to figure out a bit of the workflow. For example: Today the panel is fed its selected objects to read the key/value pairs from the Object Properties page events. This system knows when to add/remove objects from the panel as well as when to show/hide the panel. If we recreate this panel as a permanent static panel, then you’ll need either a refresh objects button on the panel or a document selection event monitor that gets/sets key values from if that makes sense. Neither of which are complicated, but just things to be considered.
Here’s the code I shared with Andy after poking around to see if this could actually work. I put the panel in a popup dialog as a quick test.
var usp = new Rhino.UI.ObjectProperties.UserStringsPanelControl();
usp.SelectedObjects = doc.Objects.GetSelectedObjects(false, false).ToArray();
usp.GetSelectedObjectUserText(usp.SelectedObjects, true);
var cmd = new CommandDialog() { Title = "Custom User Text Dialog" };
cmd.Content = usp;
cmd.Resizable = true;
cmd.ShowModal(RhinoEtoApp.MainWindow);
I think this needs a bit of a tune up so that you can have a proper panel constructor that takes the selected objects by default and processes them vs setting the selectedobjects and then calling the GetSelectedObjectUserText function directly after calling the constructor, but it does currently work, ugly, but works. I’ve created a YT here for this. RH-74462
@cadmaster That might be good enough. How do I show two?
@cadmaster How can I show two properties panels ?
- Right click next to a tab and uncheck ‘Lock Docked Windows’.
- Drag a panel to the viewport.
- Dock the panel below your other panels.
Thanks! Great hack! (works only in Rhino 8 though)
The screen recording above is from Rhino 7.
It’s not much different in Rhino 8. You just need to drag the container to the small blue square.
@martinsiegrist your screen recording from Rhino 7 does not show two properties windows. The screenshot from @cadmaster is for Rhino 8. However the workflow that you show in your screen recording can be used in Rhino 8 to make two properties windows. One to show the name and the layer, and the other to show the user text.
@Trav this hack allows seeing object’s name and user text at the same time. So it is a workaround to https://mcneel.myjetbrains.com/youtrack/issue/RH-39315#u=1494831427088
Makes sense now.
