I have inserted an image with Picture to my model. I use Make2D to export and then do a quick render in photoshop.
Is there anyway I can keep the image with the make2D export? I would like to avoid trying to reshape the image in photoshop, if pssible.
For context the model is a shop front and the image is a graphic on a window. This is only a quick model and quick render that i include with quotes to allow the client to better visualise the proposal.
Hi Paul -
I’ll have to trace the image to include it in the Make2D process. Depending on the specific needs, the Vectorize plug-in might help you on the way.
Hi Paul,
could be useful to use layout (to compose image + make2d) and print to PDF to export from Rhino to Photoshop?
An Example PDF_Raster_Vector.pdf (1.5 MB)
Ciao!
