My Make2d command isn’t working; its showing random lines that aren’t there and leaving out ones that are. Have tried moving it to 0,0 and it hasn’t corrected it
Need help asap!!
Need help asap!!
Is it a perspective view you are trying to output?
Hi Nicole,
Can you upload the file to https://www.rhino3d.com/upload
Which version of Rhino are you using?
Yes this is perspective view, have tried moving it to the origin. Its a large file but I havent had problems like this before. Using rhino 5
Thanks
Hey @nicole27793
I always had problems with large perspectives on Make2D (since 2008…) and I find that the viewport angle is to blame. I normally model my stuff using a camera Lens Length of 17 (I think the standard is set to 50).
There are two things you can do:
Hope this helps.
Have tried this today and is still doing the same thing unfortunately any other tips?
Any chance you can share the file?
Tried uploading and even in a zip file its too large
Any chance the viewport is moved in any way while make2D is running?
I leave my computer to do it so there is no chance of the viewport moving, have tried numerous things and still getting the same effect. What email shall I we transfer to?
I think you can post the transfer link here on the post. It will expire automatically in X days. Otherwise send it to tzeroarquitetura at gmail.
Thanks
Got your file.
It is really weird. It appears some of the geometries do not render at all.
I’ve tried to explode all objects and tried Perspective mode and Isometric Make2D, but to no avail.
I have saved a mesh with the problem here:
part_Make2D.3dm (5.5 MB)
Maybe someone from McNeel can have a go?
