Hi Brian,
Using: Version 5 SR12 64-bit ( 8/10/2015)
I can’t send the file right now because of an IP issue. I actually tried to recreate the problem with another object but it works fine. I realized the problem only seems to happen when I’m “inside” of the object I’m tying to Make2D with. As soon as I zoom “outside” the object Make2d works fine.
Thanks for the extra info. I have seen this before and it’s been fixed in the v6 WIP as of a year ago. If you are registered on the forum with an email address associated with a v5 license you should see the Serengeti category if you’d like to try the WIP. The download link is in Bob’s welcome message in that category.
Sorry Brian I didn’t realize you had written back. You’re correct, I meant V6.
My main concern is that all the plugins I used with grasshopper (mesh tools, human…etc.) wouldn’t work. I’m not entirely sure how that kind of thing transfers. Sounds like I should be fine.
One of our goals is to try and keep as many grasshopper components working as possible in V6. If you experience problems with any of them we sure would like to know about it. Thanks
