Main Screen Setup
Could someone please point me in the right direction.
This is a screen shot of the main screen. v8
The top menu is missing, the small ‘file read’ popup stays on screen until its clicked and when i type a command it also ends up on a separate small screen rather than in the menu panel (which is not showing)
I have spent quite some time going through every button i can find, with no luck.
Many thanks.
Try typing in WindowLayout and reset to the Default
Excellent, that worked. Many thanks.
Thank you, great community…some background.
This is a simple 3mm SS BBQ pan to be sent to the laser guy. My first real try at something external and useable. 3mm thick edge, welded to 3mm thick base.
I’m a Vectorworks Designer, trying to learn Rhino. I use VW for all sorts of design works for buildings, complex flashings and graphics. I have a client who did some modeling in Rhino for artwork, i ended up importing into VW to fix it up, but i also see some amazing works created in Rhino, so its a learning process.
Ultimately I would like to design and build another boat. Have done one before out of 12mm HDPE but used Touchcad for that. Great software but does not run on the latest macs.
I think it will take quite awhile to get my head around RH at the rate i’m going. Muscle memory in VW is very high and knowing where to look for the right command and what i am trying to achieve.
