Hei,
is there a way, beside VBS, to select a simple osnap (e.G. “mid”) in a Macro?
for example a mid snap for a pipe macro:
_-Pipe
_Pause
_Cap=_Round
.05
.05
_Pause
>>select/snap to midpoint of curve<<
.15
_Enter
thanks in advance!
Hei,
_-Pipe
_Pause
_Cap=_Round
.05
.05
_Pause
.15
_Enter
thanks in advance!
Hello - put a “Mid” in there before the Pause
.05
.05
Mid
Pause
.15
Hmm, thought so too, tried before and after Pause, does not work for me.(also not in WIP)
Open new Document.
Draw simple controll point curve (3clicks only)
Macro:
_-Pipe
_Pause
_Cap=_Round
.05
.05
_Mid
_Pause
.15
_Enter
Command-Line Output:
Command: _-Pipe
Command: _Pause
Start radius <0.050> ( Diameter Thick=No Cap=Round ShapeBlending=Local FitRail=No ): Cap=_Round
Start radius <0.050> ( Diameter Thick=No Cap=Round ShapeBlending=Local FitRail=No ): .05
End radius <0.050> ( Diameter ShapeBlending=Local FitRail=No ): .05
Point for next radius. Press Enter for none: _Mid
Point for next radius. Press Enter for none: _Pause
After Pause i need to click on mid-snap for the macro to finish.
"Mid"
command is accepted with no error but takes no effect.
Removing the Pause
leads to a straight pipe.
Hello - you do need to click on the mid point, that is not automatic -
! _-Pipe_Pause
_Cap=_Round.05
.05_Mid
_Pause.15
_Enter`
woks here.
