something is messed up with the floating windows / panels / dialogs - whatever you call them:
(1)
_curvatureGraph
_draftAngleAnalysis
can not exist at the same time.
_setPt will temporary close the _curvatureGraph or _draftAngleAnalysis dialog.
(2)
while a command dialog (floating dialog window) is active - some commands allow to interact with (for example) the Layerpanel:
_blendCrv, while in preview change the layer works fine
_loft no interaction with Layer possible
or other issues here:
_offset allows to change the Layer, while in the command, but the preview Color is wrong.
reported here without attention
thanks for more consistency - same stuff (from a users perspective) should work the same way, so fingers muscle memory can decide on the amount of clicks… (I know on the technical / implementation side this might by a completely different issue)
best -tom
