On Mac grasshopper when you hit return nothing happens, so you can’t easily, properly, set up snaps. In order to set it up you have to type the numbers elsewhere with return, or copy and paste from eslewhere a “return”.
The edit snapping I’m talking about:
When you press return nothing happens:
So you have to type it elsewhere:
Then paste it in:
This is a separate issue, but when you hover of “Values” for more than a half second if automatically has you edit those. Is there a way to extend that time so I don’t have to click out of that every time I accidentally stop over it?
