Losing disk space on every time I use Rhino 6
I’m having a problem with the drive usage space, on every time I use Rhino, the free space is getting smaller and smaller, I tried to clean all the temps folders, cache, used the CCleaner and so on, but I cannot find where are missing the (now it is) 8gb of free space, that I had before.
Whenever I use the Rhino, the free space decreases.
I am using also the Vray, but even when I am not touching in this plugin, the space steadily decreases…
Can someone help me on this before I run out of space? Thanks
Wonder if it’s your autosave files - now they are stored in the trash instead of being deleted… Check there maybe?
Rhino’s Autosave files are now moved to the Windows Recycle Bin.
Is yours filling up?
I can not recommend use of CCleaner or anything similar.
With the low cost of storage, why are you living with so little room?
I always empty the recycle bin, and as I mention, not only I clean manually all the temps folders that I could find,I also use CCleaner to help me on this task.
About buying a new disk, even if I would have 1TB of free space, by this rate, I would run out of space in 6 months… Because I already lost 8Gb of space in just one week of work with Rhino. My file size is around 200Mb.
Maybe you just need a bigger disk. You can get a 4TB (4194304 MB) disk drive for around $70US
That does not answer why did fly away 8gb or more of space with just one working file of 200Mb…
Have you tried purging your TEMP folder?
is clean
I have seen a few cases with Vray where material definitions were being duplicated and saved multiple times within a file.
It is file specific and specific to Vray.
If you look at a 3dm file size, open it, do a couple small things, then save it, is the file itself getting a lot larger?
This was the symptom we were seeing.
As I recall this was some time ago, right? That we were seeing Vray related file bloat? I believe a new version fixed all that… @ripedro - what version of Vray do you have? Can you please run SystemInfo in Rhino and post the results?
I am using the last version Vray, is in demo mode, because I am learning to work with it in Rhino.
Maybe can be a clue, there was a moment before this last Rhino release (2 days ago), it was crashing a lot, many times I could not find a direct relation with Vray, but there was always something telling me that could be Vray causing those craches. Today no crash has happen.
Here is the System info:
Rhino 6 SR13 2019-2-27 (Rhino 6, 6.13.19058.371, Git hash:master @ 17cd8b51accbe17dd04b48028f49d5e77a67f17b)
License type: Educational, build 2019-02-27
License details: Stand-Alone
Windows 10.0 SR0.0 or greater (Physical RAM: 12Gb)
Hybrid graphics system.
Primary display: Intel® HD Graphics 4600 (Intel) Memory: 1GB, Driver date: 11-10-2016 (M-D-Y).
Primary OpenGL: NVIDIA GeForce GT 750M (NVidia) Memory: 2GB, Driver date: 1-23-2018 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 390.77
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 1-23-2018
Driver Version: 23.21.13.9077
Z-Buffer depth: 24 bits
Total Video Memory: 2 GB
Rhino plugins
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands” 6.13.19058.371
C:\Program Files\Rhino 6\Plug-ins\RhinoBonusTools.rhp “Rhino Bonus Tools”
C:\Program Files\Rhino 6\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 6.13.19058.371
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles” 6.13.19058.371
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 6.13.19058.371
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros 6\VRayForRhino.rhp “V-Ray for Rhino”
C:\Program Files\Rhino 6\Plug-ins\Calc.rhp “Calc”
C:\Program Files\Rhino 6\Plug-ins\NamedPositions.rhp “Named Position”
Hello - is any of the Rhino files unexpectedly large?
could you help me to find it out?
Hello - please run Audit3dmFIle and locate one of the files you’ve been working with - post the results here…
Testing 3dm Archive: D:.…\Vector\Planta da casa V1_2-2.3dm
Start Section: 453 bytes (offset 0 to 453)
Offset: 0
3dm archive version: 60
Interface Name: Rhinoceros 6.12 - Educational, build 2019-01-29 - (compiled Jan 29 2019)
SDK Version: 2348836105.2351983977
OpenNURBS Version: 2351983977
3dm Version: 6
Operating System: Windows 10.0 SR0.0 or greater, 64-bit, platform 0, version 10.0 build 0 sp 0.0, suite 0, product type 0
Runtime: ON::RuntimeEnvironment::Windows 3DM I/O processor: OpenNURBS toolkit version 2351983977 (compiled on Jan 29 2019)
Properties Section: 253145 bytes (offset 453 to 253598)
3dm archive openNURBS version: 2351983977 (6.12 2019-01-29:1)
Application Information:
URL: “http://www.rhino3d.com”
Details: “Educational, build 2019-01-29”
Revision History:
Create Time: Saturday December 08 09:33:27 2018 UCT
Last Edit Time: Saturday March 02 14:47:03 2019 UCT
Revision Count: 160
Created By: “…”
Last Edit By: “…”
Settings Section: 41995 bytes (offset 253598 to 295593)
Model length unit system: centimeters
Page length unit system: millimeters
Plug-ins:
Name: 3Dconnexion 3D Mouse
Version: 6.12.19029.06381
File: C:\Program Files\Rhino 6\Plug-ins\3dxrhino.rhp
SDK Version: C++ 2348836105.2351983977 (6.0 2017-08-15:1, 6.12 2019-01-29:1)
Version: Jan 29 2019 06:58:04
File: C:\Program Files\Rhino 6\Plug-ins\AnimationTools.rhp
Version: Jan 29 2019 06:58:01
File: C:\Program Files\Rhino 6\Plug-ins\Calc.rhp
Version: 6.12.19029.6381
File: C:\Program Files\Rhino 6\Plug-ins\Commands.rhp
SDK Version: .NET 0.0
Version: Jan 29 2019 07:00:24
File: C:\Program Files\Rhino 6\Plug-ins\Displacement.rhp
Version: Jan 29 2019 06:59:37
File: C:\Program Files\Rhino 6\Plug-ins\NamedPositions.rhp
File: C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp
Name: Renderer Development Kit
Version: Jan 29 2019 06:56:03
File: C:\Program Files\Rhino 6\Plug-ins\rdk.rhp
Name: Renderer Development Kit UI
Version: Jan 29 2019 06:57:32
File: C:\Program Files\Rhino 6\Plug-ins\rdk_ui.rhp
Name: Rhino Bonus Tools
Version: Jan 29 2019 06:59:22
File: C:\Program Files\Rhino 6\Plug-ins\RhinoBonusTools.rhp
Version: 1.50, Jan 29 2019, 06:57:11
File: C:\Program Files\Rhino 6\Plug-ins\RhinoRender.rhp
File: C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp
Version: Jan 29 2019 07:03:06
File: C:\Program Files\Rhino 6\Plug-ins\RPC.rhp
Version: Jan 29 2019 07:01:30
File: C:\Program Files\Rhino 6\Plug-ins\NamedSnapshots.rhp
File: C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp
Name: V-Ray for Rhino
Version: 3.60.03 adv ( Jul 3 2018 )
File: C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros 6\VRayForRhino.rhp
SDK Version: C++ 2348836105.2350148005 (6.0 2017-08-15:1, 6.5 2018-06-04:1)
Embedded image Table:
EmbeddedImage[0]: D:\Users\Obras\Bitmaps\Casa R José Dias Coelho Plantas 2o andar.jpg
EmbeddedImage[1]: D:\Obras\Bitmaps\Prédio José Dias Coelho 30 - 2º Andar.jpg
2 embedded images, 2356298 bytes (offset 295593 to 2651891)
Texture Mapping Table:
mapping[0]:
mapping[1]:
mapping[2]:
mapping[3]:
mapping[4]:
mapping[5]:
mapping[6]:
mapping[7]:
mapping[119]:
120 texture mappings with 69 plug-in data items, 98003 bytes (offset 2651891 to 2749894)
Material Table:
material[0]: /Branco 9001
material[1]: window2
material[2]: glass_border1
material[3]: window1
material[4]: window1
material[5]: window1
material[6]: window2
material[7]: window1
material[599]: /Paint_White
600 materials with 544 plug-in data items, 695490 bytes (offset 2749894 to 3445384)
Linetype Table:
0 linetypes, 24 bytes (offset 3445384 to 3445408)
Layer Table:
layer[0]: Closet
layer[1]: Paredes Grossos
layer[2]: Paredes Finos
layer[3]: Janelas e madeiras
layer[4]: WC
layer[5]: Serviço
layer[6]: Tectos
layer[7]: Chão
layer[8]: Default
layer[9]: Layer 01
layer[10]: 0
layer[11]: Cozinha
layer[12]: drez
layer[13]: baterie
layer[14]: Janelas
layer[15]: SANINDUSA
layer[16]: Accessories
layer[17]: Bird_Decoration
layer[18]: Small_Cactus_Vase
layer[19]: Small_Cactus
layer[20]: Geometric_Vase
layer[21]: Sphere_Vases
layer[22]: Water
layer[23]: Plants
24 layers, 6066 bytes (offset 3445408 to 3451474)
Group Table:
group[0]: Group01
group[1]: Group02
group[2]: Group13
group[3]: Group14
group[4]: Group15
group[5]: Group18
group[6]: Group20
group[7]: Group21
group[132]: Group49
133 groups, 17205 bytes (offset 3451474 to 3468679)
Annotation Style Table:
annotation style[0]: Centímetros
1 annotation styles, 1408 bytes (offset 3468679 to 3470087)
Light Table:
light[0]: V-Ray Rectangle Light_Light 01
light[1]: V-Ray Rectangle Light_Light 01
light[2]: V-Ray Rectangle Light WC espelho_Light 01
light[3]: V-Ray Rectangle Light WC espelho_Light 01
light[4]: V-Ray Rectangle Light_Light 01
light[5]: V-Ray Rectangle Light_Light 01
light[6]: Light IES#1_Light 01
light[7]: Light IES#1_Light 01
light[15]: V-Ray Sphere Light_Light 01
16 lights with 18 plug-in data items, 30086 bytes (offset 3470087 to 3500173)
HatchPattern Table:
hatchpattern[0]: Hatch1
hatchpattern[1]: Hatch2
hatchpattern[2]: Hatch3
hatchpattern[3]: HatchDash
hatchpattern[4]: Grid
hatchpattern[5]: Grid60
hatchpattern[6]: Plus
hatchpattern[7]: Squares
8 hatchpatterns, 2908 bytes (offset 3500173 to 3503081)
Block Definition Table:
linked and embedded block definition[0]: name = “Janelas” id = 59b76572-fe16-417c-b912-a967029fb770
linked and embedded block definition[1]: name = “Sanindusa - Lavatório morfys 53x39” id = c1dc594e-d1bd-4602-954a-e34bf8d56bc2
linked and embedded block definition[2]: name = “Consola pqna” id = 00a420c6-a51a-4fc7-bffe-23e9437e9bd4
block definition[3]: name = “Franke_Set” id = 9e4387ca-03af-4a20-94e3-f9dc24782f95
block definition[4]: name = “Microondas” id = 772e29ba-c1f6-4cd5-86d2-8c49f21f4759
linked and embedded block definition[5]: name = “Torneira alta New Ícone” id = 76584653-d3bc-47cc-9aff-a7ff504a7f21
=) can you just post a text file?
Oh! Sorry!
File Audict.txt (117.2 KB)
So, the file itself does not seem to be the problem, from what I can see. If you block VRay in Options > Plug-ins page and then restart Rhino do you see the disk space being eaten up as before?
OMG! This is geting even more weird…
I made now some tests: One week ago I had 21Gb of free space.
Now, when I started to do the testing I had 13.2GB; First test, I open the same file in which today morning I had +/-15Gb space free, made a VRay render of a scene. Finished, save it and close Rhino. Final result = 13.2 GB. Second test: I followed your instructions… Final result = 13.1GB, but maybe this small difference is also related with the internet browser, where I am writing this post.
Hello Ripedro,
When you save your files do you get the *.3dmbak files ?
Thank you,
Andy
