Hello, I have long verification times every time, minimum or around 4 minutes. Running on 16" M1 (forgot the spec details) but it shouldn’t be a hardware issue.
Hi Xinxin Annie Lin,
When you say verification times is this Rhino booting up or an actual verification dialog?
Can you tell us a little about your internet/network environment?
SystemInfo (type in Rhino command line) might help here as well. Thanks
This happens during startup of the app.
I remember the first few times I ran Rhino on this laptop, every time I quit the app, I’ve had to re-install it to open it. Now I never quit Rhino specifically. It’s somehow not permanent on my laptop?
How are you starting Rhino? It appears you are clicking on the .dmg, which will install, not open.
The first few times, Rhino would uninstall when I manually Quit (right click icon/Quit). I believe it uninstalled because all the Rhino files would have a blank paper icon. Since then I would never manually exit Rhino to avoid re-installation. I just close out the file and shut down. Now, to open, I click on the Rhino 7 icon in dock but it still loads with that dialogue.
I typically open via spotlight search.
Please type SystemInfo in the Rhino command line and return the results here, thanks.
Rhino 7 SR27 2023-2-1 (Rhino 7, 7.27.23032.13002, Git hash:master @ 4a0030c0d354560df03764f4f49ecc5d119e5118)
License type: Commercial, build 2023-02-01
License details: Cloud Zoo
Apple macOS Version 12.5 (Build 21G72) (Physical RAM: 16Gb)
Rhino is running in Rosetta2 on Apple Silicon
Mac Model Identifier: MacBookPro18,1
Language: en-AU (MacOS default)
Apple M1 Pro (OpenGL ver:4.1 Metal - 76.3)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Apple
Render version: 4.1
Shading Language: 4.10
Z-Buffer depth: n/a
Total Video Memory: 10922 MB
Graphics: Apple M1 Pro
Displays: Unknown (255dpi 2x), Unknown (109dpi 1x)
Graphics processors
Apple M1 Pro
Color LCD (1728 x 1117 @ 120.00Hz)
LG ULTRAWIDE (3440 x 1440 @ 85.00Hz)
USB devices
Logitech: USB Receiver
Bluetooth devices
None
Third party kernel extensions
None
Third party plugins
/usr/lib/swift/libswiftCloudKit.dylib
/usr/lib/swift/libswiftCoreData.dylib
/usr/lib/swift/libswiftFoundation.dylib
/usr/lib/swift/libswiftAppKit.dylib
/usr/lib/swift/libswiftContacts.dylib
/usr/lib/swift/libswiftCoreML.dylib
/usr/lib/swift/libswiftVision.dylib
/usr/lib/swift/libswiftNetwork.dylib
/usr/lib/swift/libswiftFileProvider.dylib
/usr/lib/swift/libswiftPrivate_BiomePubSub.dylib
/usr/lib/swift/libswiftPrivate_BiomeStreams.dylib
/var/folders/kq/tbhkhjtn553849_gg86f72wm0000gn/T/AppTranslocation/E99B85AB-7FBF-46DE-912A-72838EEC18D5/d/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 7.27.23032.13002
/var/folders/kq/tbhkhjtn553849_gg86f72wm0000gn/T/AppTranslocation/E99B85AB-7FBF-46DE-912A-72838EEC18D5/d/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 7.27.23032.13002
/var/folders/kq/tbhkhjtn553849_gg86f72wm0000gn/T/AppTranslocation/E99B85AB-7FBF-46DE-912A-72838EEC18D5/d/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 7.27.23032.13002
/var/folders/kq/tbhkhjtn553849_gg86f72wm0000gn/T/AppTranslocation/E99B85AB-7FBF-46DE-912A-72838EEC18D5/d/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 7.27.23032.13002
/var/folders/kq/tbhkhjtn553849_gg86f72wm0000gn/T/AppTranslocation/E99B85AB-7FBF-46DE-912A-72838EEC18D5/d/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/BlockEdit.rhp “BlockEdit” 7.27.23032.13002
/var/folders/kq/tbhkhjtn553849_gg86f72wm0000gn/T/AppTranslocation/E99B85AB-7FBF-46DE-912A-72838EEC18D5/d/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 7.27.23032.13002
/var/folders/kq/tbhkhjtn553849_gg86f72wm0000gn/T/AppTranslocation/E99B85AB-7FBF-46DE-912A-72838EEC18D5/d/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 7.27.23032.13002
/private/var/folders/kq/tbhkhjtn553849_gg86f72wm0000gn/T/AppTranslocation/E99B85AB-7FBF-46DE-912A-72838EEC18D5/d/Rhino 7.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 7.27.23032.1002
/private/var/folders/kq/tbhkhjtn553849_gg86f72wm0000gn/T/AppTranslocation/E99B85AB-7FBF-46DE-912A-72838EEC18D5/d/Rhino 7.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 7.27.23032.1002
/private/var/folders/kq/tbhkhjtn553849_gg86f72wm0000gn/T/AppTranslocation/E99B85AB-7FBF-46DE-912A-72838EEC18D5/d/Rhino 7.app/Contents/PlugIns/AnimationTools.rhp “AnimationTools” 7.27.23032.1002
/private/var/folders/kq/tbhkhjtn553849_gg86f72wm0000gn/T/AppTranslocation/E99B85AB-7FBF-46DE-912A-72838EEC18D5/d/Rhino 7.app/Contents/PlugIns/CreaseAngle.rhp “CreaseAngle” 7.27.23032.1002
/private/var/folders/kq/tbhkhjtn553849_gg86f72wm0000gn/T/AppTranslocation/E99B85AB-7FBF-46DE-912A-72838EEC18D5/d/Rhino 7.app/Contents/PlugIns/Displacement.rhp “Displacement” 7.27.23032.1002
/private/var/folders/kq/tbhkhjtn553849_gg86f72wm0000gn/T/AppTranslocation/E99B85AB-7FBF-46DE-912A-72838EEC18D5/d/Rhino 7.app/Contents/PlugIns/export_3DS.rhp “3D Studio Export” 7.27.23032.1002
/private/var/folders/kq/tbhkhjtn553849_gg86f72wm0000gn/T/AppTranslocation/E99B85AB-7FBF-46DE-912A-72838EEC18D5/d/Rhino 7.app/Contents/PlugIns/export_3MF.rhp “export_3MF” 7.27.23032.1002
/private/var/folders/kq/tbhkhjtn553849_gg86f72wm0000gn/T/AppTranslocation/E99B85AB-7FBF-46DE-912A-72838EEC18D5/d/Rhino 7.app/Contents/PlugIns/export_ACAD.rhp “AutoCAD file export : export_ACAD” 7.27.23032.1002
/private/var/folders/kq/tbhkhjtn553849_gg86f72wm0000gn/T/AppTranslocation/E99B85AB-7FBF-46DE-912A-72838EEC18D5/d/Rhino 7.app/Contents/PlugIns/export_AI.rhp “Adobe Illustrator Export” 7.27.23032.1002
/private/var/folders/kq/tbhkhjtn553849_gg86f72wm0000gn/T/AppTranslocation/E99B85AB-7FBF-46DE-912A-72838EEC18D5/d/Rhino 7.app/Contents/PlugIns/Export_CD.rhp “Cult3D Export” 7.27.23032.1002
/private/var/folders/kq/tbhkhjtn553849_gg86f72wm0000gn/T/AppTranslocation/E99B85AB-7FBF-46DE-912A-72838EEC18D5/d/Rhino 7.app/Contents/PlugIns/Export_CSV.rhp “Comma Separated Value Export” 7.27.23032.1002
/private/var/folders/kq/tbhkhjtn553849_gg86f72wm0000gn/T/AppTranslocation/E99B85AB-7FBF-46DE-912A-72838EEC18D5/d/Rhino 7.app/Contents/PlugIns/export_FBX.rhp “Export_FBX” 7.27.23032.1002
/private/var/folders/kq/tbhkhjtn553849_gg86f72wm0000gn/T/AppTranslocation/E99B85AB-7FBF-46DE-912A-72838EEC18D5/d/Rhino 7.app/Contents/PlugIns/Export_GTS.rhp “GTS Export” 7.27.23032.1002
/private/var/folders/kq/tbhkhjtn553849_gg86f72wm0000gn/T/AppTranslocation/E99B85AB-7FBF-46DE-912A-72838EEC18D5/d/Rhino 7.app/Contents/PlugIns/export_LWO.rhp “Lightwave Export” 7.27.23032.1002
/private/var/folders/kq/tbhkhjtn553849_gg86f72wm0000gn/T/AppTranslocation/E99B85AB-7FBF-46DE-912A-72838EEC18D5/d/Rhino 7.app/Contents/PlugIns/export_Points.rhp “Points Export” 7.27.23032.1002
/private/var/folders/kq/tbhkhjtn553849_gg86f72wm0000gn/T/AppTranslocation/E99B85AB-7FBF-46DE-912A-72838EEC18D5/d/Rhino 7.app/Contents/PlugIns/Export_POV.rhp “POV-Ray Export” 7.27.23032.1002
/private/var/folders/kq/tbhkhjtn553849_gg86f72wm0000gn/T/AppTranslocation/E99B85AB-7FBF-46DE-912A-72838EEC18D5/d/Rhino 7.app/Contents/PlugIns/Export_RAW.rhp “Raw Triangles Export” 7.27.23032.1002
/private/var/folders/kq/tbhkhjtn553849_gg86f72wm0000gn/T/AppTranslocation/E99B85AB-7FBF-46DE-912A-72838EEC18D5/d/Rhino 7.app/Contents/PlugIns/Export_RIB.rhp “Renderman Export” 7.27.23032.1002
/private/var/folders/kq/tbhkhjtn553849_gg86f72wm0000gn/T/AppTranslocation/E99B85AB-7FBF-46DE-912A-72838EEC18D5/d/Rhino 7.app/Contents/PlugIns/export_SAT.rhp “ACIS Export” 7.27.23032.1002
/private/var/folders/kq/tbhkhjtn553849_gg86f72wm0000gn/T/AppTranslocation/E99B85AB-7FBF-46DE-912A-72838EEC18D5/d/Rhino 7.app/Contents/PlugIns/export_SKP.rhp “SketchUp Export” 7.27.23032.1002
/private/var/folders/kq/tbhkhjtn553849_gg86f72wm0000gn/T/AppTranslocation/E99B85AB-7FBF-46DE-912A-72838EEC18D5/d/Rhino 7.app/Contents/PlugIns/export_SLC.rhp “SLC Export” 7.27.23032.1002
/private/var/folders/kq/tbhkhjtn553849_gg86f72wm0000gn/T/AppTranslocation/E99B85AB-7FBF-46DE-912A-72838EEC18D5/d/Rhino 7.app/Contents/PlugIns/export_STEP.rhp “STEP Export” 7.27.23032.1002
/private/var/folders/kq/tbhkhjtn553849_gg86f72wm0000gn/T/AppTranslocation/E99B85AB-7FBF-46DE-912A-72838EEC18D5/d/Rhino 7.app/Contents/PlugIns/export_STL.rhp “STL Export” 7.27.23032.1002
/private/var/folders/kq/tbhkhjtn553849_gg86f72wm0000gn/T/AppTranslocation/E99B85AB-7FBF-46DE-912A-72838EEC18D5/d/Rhino 7.app/Contents/PlugIns/Export_UDO.rhp “Moray Export” 7.27.23032.1002
/private/var/folders/kq/tbhkhjtn553849_gg86f72wm0000gn/T/AppTranslocation/E99B85AB-7FBF-46DE-912A-72838EEC18D5/d/Rhino 7.app/Contents/PlugIns/export_VDA.rhp “VDA Export” 7.27.23032.1002
/private/var/folders/kq/tbhkhjtn553849_gg86f72wm0000gn/T/AppTranslocation/E99B85AB-7FBF-46DE-912A-72838EEC18D5/d/Rhino 7.app/Contents/PlugIns/export_VRML.rhp “VRML/X3D Export” 7.27.23032.1002
/private/var/folders/kq/tbhkhjtn553849_gg86f72wm0000gn/T/AppTranslocation/E99B85AB-7FBF-46DE-912A-72838EEC18D5/d/Rhino 7.app/Contents/PlugIns/Export_WAMIT.rhp “WAMIT Export” 7.27.23032.1002
/private/var/folders/kq/tbhkhjtn553849_gg86f72wm0000gn/T/AppTranslocation/E99B85AB-7FBF-46DE-912A-72838EEC18D5/d/Rhino 7.app/Contents/PlugIns/Export_X.rhp “X Export” 7.27.23032.1002
/private/var/folders/kq/tbhkhjtn553849_gg86f72wm0000gn/T/AppTranslocation/E99B85AB-7FBF-46DE-912A-72838EEC18D5/d/Rhino 7.app/Contents/PlugIns/Export_X_T.rhp “Parasolid Export” 7.27.23032.1002
/private/var/folders/kq/tbhkhjtn553849_gg86f72wm0000gn/T/AppTranslocation/E99B85AB-7FBF-46DE-912A-72838EEC18D5/d/Rhino 7.app/Contents/PlugIns/Export_XGL.rhp “XGL Export” 7.27.23032.1002
/private/var/folders/kq/tbhkhjtn553849_gg86f72wm0000gn/T/AppTranslocation/E99B85AB-7FBF-46DE-912A-72838EEC18D5/d/Rhino 7.app/Contents/PlugIns/import_3MF.rhp “import_3MF” 7.27.23032.1002
/private/var/folders/kq/tbhkhjtn553849_gg86f72wm0000gn/T/AppTranslocation/E99B85AB-7FBF-46DE-912A-72838EEC18D5/d/Rhino 7.app/Contents/PlugIns/import_ACAD.rhp “AutoCAD file import: import_ACAD” 7.27.23032.1002
/private/var/folders/kq/tbhkhjtn553849_gg86f72wm0000gn/T/AppTranslocation/E99B85AB-7FBF-46DE-912A-72838EEC18D5/d/Rhino 7.app/Contents/PlugIns/import_FBX.rhp “Import_FBX” 7.27.23032.1002
/private/var/folders/kq/tbhkhjtn553849_gg86f72wm0000gn/T/AppTranslocation/E99B85AB-7FBF-46DE-912A-72838EEC18D5/d/Rhino 7.app/Contents/PlugIns/Import_GTS.rhp “GTS Triangle Import” 7.27.23032.1002
/private/var/folders/kq/tbhkhjtn553849_gg86f72wm0000gn/T/AppTranslocation/E99B85AB-7FBF-46DE-912A-72838EEC18D5/d/Rhino 7.app/Contents/PlugIns/import_IGES.rhp “IGES Import Plug-in” 7.27.23032.1002
/private/var/folders/kq/tbhkhjtn553849_gg86f72wm0000gn/T/AppTranslocation/E99B85AB-7FBF-46DE-912A-72838EEC18D5/d/Rhino 7.app/Contents/PlugIns/import_LWO.rhp “Lightwave Import” 7.27.23032.1002
/private/var/folders/kq/tbhkhjtn553849_gg86f72wm0000gn/T/AppTranslocation/E99B85AB-7FBF-46DE-912A-72838EEC18D5/d/Rhino 7.app/Contents/PlugIns/Import_M.rhp “Import_M” 7.27.23032.1002
/private/var/folders/kq/tbhkhjtn553849_gg86f72wm0000gn/T/AppTranslocation/E99B85AB-7FBF-46DE-912A-72838EEC18D5/d/Rhino 7.app/Contents/PlugIns/Import_OFF.rhp “OFF Import” 7.27.23032.1002
/private/var/folders/kq/tbhkhjtn553849_gg86f72wm0000gn/T/AppTranslocation/E99B85AB-7FBF-46DE-912A-72838EEC18D5/d/Rhino 7.app/Contents/PlugIns/import_PDF.rhp “PDFReader” 7.27.23032.1002
/private/var/folders/kq/tbhkhjtn553849_gg86f72wm0000gn/T/AppTranslocation/E99B85AB-7FBF-46DE-912A-72838EEC18D5/d/Rhino 7.app/Contents/PlugIns/import_PLY.rhp “PLY - Polygon File Format Import” 7.27.23032.1002
/private/var/folders/kq/tbhkhjtn553849_gg86f72wm0000gn/T/AppTranslocation/E99B85AB-7FBF-46DE-912A-72838EEC18D5/d/Rhino 7.app/Contents/PlugIns/import_Points.rhp “Points Import” 7.27.23032.1002
/private/var/folders/kq/tbhkhjtn553849_gg86f72wm0000gn/T/AppTranslocation/E99B85AB-7FBF-46DE-912A-72838EEC18D5/d/Rhino 7.app/Contents/PlugIns/import_RAW.rhp “RAW Triangle Import” 7.27.23032.1002
/private/var/folders/kq/tbhkhjtn553849_gg86f72wm0000gn/T/AppTranslocation/E99B85AB-7FBF-46DE-912A-72838EEC18D5/d/Rhino 7.app/Contents/PlugIns/import_SKP.rhp “SketchUp Import” 7.27.23032.1002
/private/var/folders/kq/tbhkhjtn553849_gg86f72wm0000gn/T/AppTranslocation/E99B85AB-7FBF-46DE-912A-72838EEC18D5/d/Rhino 7.app/Contents/PlugIns/Import_SLC.rhp “SLC Import” 7.27.23032.1002
/private/var/folders/kq/tbhkhjtn553849_gg86f72wm0000gn/T/AppTranslocation/E99B85AB-7FBF-46DE-912A-72838EEC18D5/d/Rhino 7.app/Contents/PlugIns/Import_SolidWorks.rhp “Solidworks Import” 7.27.23032.1002
/private/var/folders/kq/tbhkhjtn553849_gg86f72wm0000gn/T/AppTranslocation/E99B85AB-7FBF-46DE-912A-72838EEC18D5/d/Rhino 7.app/Contents/PlugIns/import_STEP.rhp “STEP Import” 7.27.23032.1002
/private/var/folders/kq/tbhkhjtn553849_gg86f72wm0000gn/T/AppTranslocation/E99B85AB-7FBF-46DE-912A-72838EEC18D5/d/Rhino 7.app/Contents/PlugIns/import_STL.rhp “STL Import” 7.27.23032.1002
/private/var/folders/kq/tbhkhjtn553849_gg86f72wm0000gn/T/AppTranslocation/E99B85AB-7FBF-46DE-912A-72838EEC18D5/d/Rhino 7.app/Contents/PlugIns/import_VDA.rhp “VDA Import” 7.27.23032.1002
/private/var/folders/kq/tbhkhjtn553849_gg86f72wm0000gn/T/AppTranslocation/E99B85AB-7FBF-46DE-912A-72838EEC18D5/d/Rhino 7.app/Contents/PlugIns/import_VRML.rhp “VRML Import” 7.27.23032.1002
/private/var/folders/kq/tbhkhjtn553849_gg86f72wm0000gn/T/AppTranslocation/E99B85AB-7FBF-46DE-912A-72838EEC18D5/d/Rhino 7.app/Contents/PlugIns/Import_WAMIT.rhp “WAMIT import” 7.27.23032.1002
/private/var/folders/kq/tbhkhjtn553849_gg86f72wm0000gn/T/AppTranslocation/E99B85AB-7FBF-46DE-912A-72838EEC18D5/d/Rhino 7.app/Contents/PlugIns/Import_X.rhp “X Import” 7.27.23032.1002
/private/var/folders/kq/tbhkhjtn553849_gg86f72wm0000gn/T/AppTranslocation/E99B85AB-7FBF-46DE-912A-72838EEC18D5/d/Rhino 7.app/Contents/PlugIns/MeshFromPoints.rhp “MeshFromPoints” 7.27.23032.1002
/private/var/folders/kq/tbhkhjtn553849_gg86f72wm0000gn/T/AppTranslocation/E99B85AB-7FBF-46DE-912A-72838EEC18D5/d/Rhino 7.app/Contents/PlugIns/MeshTools.rhp “MeshTools” 7.27.23032.1002
/private/var/folders/kq/tbhkhjtn553849_gg86f72wm0000gn/T/AppTranslocation/E99B85AB-7FBF-46DE-912A-72838EEC18D5/d/Rhino 7.app/Contents/PlugIns/MPlane.rhp “MPlane” 7.27.23032.1002
/private/var/folders/kq/tbhkhjtn553849_gg86f72wm0000gn/T/AppTranslocation/E99B85AB-7FBF-46DE-912A-72838EEC18D5/d/Rhino 7.app/Contents/PlugIns/NamedPositions.rhp “Named Position” 7.27.23032.1002
/private/var/folders/kq/tbhkhjtn553849_gg86f72wm0000gn/T/AppTranslocation/E99B85AB-7FBF-46DE-912A-72838EEC18D5/d/Rhino 7.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 7.27.23032.1002
/private/var/folders/kq/tbhkhjtn553849_gg86f72wm0000gn/T/AppTranslocation/E99B85AB-7FBF-46DE-912A-72838EEC18D5/d/Rhino 7.app/Contents/PlugIns/RhinoBonusTools.rhp “Rhino Bonus Tools” 7.27.23032.1002
/private/var/folders/kq/tbhkhjtn553849_gg86f72wm0000gn/T/AppTranslocation/E99B85AB-7FBF-46DE-912A-72838EEC18D5/d/Rhino 7.app/Contents/PlugIns/RhinoLabsTools.rhp “Rhino Labs Tools” 7.27.23032.1002
/private/var/folders/kq/tbhkhjtn553849_gg86f72wm0000gn/T/AppTranslocation/E99B85AB-7FBF-46DE-912A-72838EEC18D5/d/Rhino 7.app/Contents/PlugIns/RhinoRender.rhp “Legacy Rhino Render” 7.27.23032.1002
/private/var/folders/kq/tbhkhjtn553849_gg86f72wm0000gn/T/AppTranslocation/E99B85AB-7FBF-46DE-912A-72838EEC18D5/d/Rhino 7.app/Contents/PlugIns/SolidTools.rhp “SolidTools” 7.27.23032.1002
/private/var/folders/kq/tbhkhjtn553849_gg86f72wm0000gn/T/AppTranslocation/E99B85AB-7FBF-46DE-912A-72838EEC18D5/d/Rhino 7.app/Contents/PlugIns/Squish.rhp “Squish” 7.27.23032.1002
Its a good machine, with no plugins. Is your mac running anti-virus software?
One thing we can try is to reset your PList https://wiki.mcneel.com/rhino/mac/resetprefs
