Loft to Create Wedged Terrain?
Hello. I’m using Rhino 7 on a Mac & attempting to create terrain that goes from 0-18" The areas in green are the portions I’m referring to. I drew dashed red lines to indicate what I want to achieve. (see screenshot)
The shapes are irregular. I tried a mesh, then tried just turning on the points of the planar surface (green areas) and manipulating the points on the z plane to 18". But my points are in a square plane surrounding the object (see screenshot) and I wasn’t able to control it well. Can I do PointsOn and manipulate a planar surface directly like I’ve mentioned? I’m a beginner, I apologize.
Is there a way to quickly loft these surfaces to create the terrain I’m going for? Thank you for your help. I really appreciate it.
Hello- can you please post a file with one or two of these in their flat state?
Sure. Thanks for your response. Does this help?
Oh I just realized you meant a Rhino file not a screenshot. Here you go. Thanks again!
Scribble Sample.3dm (2.3 MB)
Is this approximately what you are shooting for, for the ‘main’ surfaces?
Scribble Sample_Maybe.3dm (196.7 KB)
Yes!! That’s exactly what I’m aiming for!!! Absolutely perfect! That’s amazing! Thank you! Can you tell me your recipe step-by-step?
Hello- first decide which way the tilt will go - it looks like some go from an edge tio an edge and others go from an edge to a point.
For edge to edge, get the relevant portion of the curve and move or copy it 18" up, and get the low end curve in place:
Loft between the two curves - I would use Rebuild in Loft to make it easier to match up non-compatible curves.
For the pointy ones, do the same thing only you will loft to a point:
Where the lofts fall inside the desired outer boundaries,
use ExtendSrf to bring them out past the boundaries:
Then in Top use the outer boundary curves to trim the surfaces back:
Oh my gosh, Pascal. I’ve spent days trying to figure this out. This is absolutely incredible. The time you took is so so kind. Screenshots of each step? I’m blown away at such kindness from a stranger. I don’t know how to thank you besides telling you you’ve saved me days of struggle and headache. I am so grateful for your help. Truly, thank you.
Well… you are welcome, of course… it’s kind of my job, really, to try to help un-stick Rhino users where I can… =)
I recommend looking through some of the examples and training material here if you have not -
In particular the Level 1 and Level 2 materials.
