Loft through Stations vs Patch layout for a Jet fuselage?
Hi All,
What the pro’s and cons are of creating a jet fuselage with a loft through cross sections verses a patch layout with 4 sided surfaces similar to what is described in the following video, and the video series “sculpt and match” wider principles?
I can understand why a patch layout would make more sense with a car because of it’s squarer nature, but with a fuselage that is generally more rounded / elliptical, would a loft still be a sensible approach? Is there any reason to prefer one method over the other?
Thanks!
Hi @Paul48,
For most of a fuselage, a loft through stations is a good approach. Aircraft are defined by stations anyway, and the main body is usually close to a tube, so a loft gives you one clean surface that is easy to control.
Loft pros
  • Matches how fuselages are normally defined (station cuts, lofting lines).
  • You get one surface with smooth curvature along its length and no internal seams to match.
  • It’s easy to edit: move or rebuild a section and loft again.
Loft cons
  • The section curves need compatible structure (same degree, same point count, aligned seams). If they don’t, you get twisting or a heavy, uneven surface.
  • It handles the ends badly. Collapsing to a point at the nose or tail cone gives a singular, pinched point.
  • It doesn’t handle big shape changes well, like the canopy, wing root and fillet, or tail cone upsweep. Trying to force those into one loft usually means adding more sections, and the surface gets lumpy.
Patch layout pros
  • Lets you split the shape where the design actually changes: nose, canopy, wing fairing, tail.
  • Each patch stays light and controllable.
  • Avoids degenerate points by giving the nose and tail cap proper 4-sided patches.
Patch layout cons
  • You need to plan more up front.
  • You have to manage continuity across the seams with MatchSrf, BlendSrf and so on.
In practice, people often do both. Loft the constant-section mid body, then use a patch layout for the nose, canopy, wing-body fairing and tail cone, matching G2 to the loft. Keep the loft sections simple and structurally the same: rebuild them to the same degree and point count, or make them by editing one master section.
– Dale
Thanks Dale — that’s very helpful. Your point about keeping the loft sections simple and structurally the same, or editing one master section, is particularly relevant to what I’m trying to do.
I’ve developed the station approach a little further and would appreciate a sanity check before I go too far with it.
Fig. 1 — Station construction
Each section is made from four open NURBS curve segments, mirrored left/right. The Top and Bottom points are constrained by the upper/lower profile guides, and the maximum-width points are constrained laterally by the plan-view guide (see Fig. 3). The remaining CVs are there purely to shape the section.
Fig. 2 — Curvature graph
This is the same section with G2 at Top, maximum width and Bottom. I’m deliberately trying to keep the CV count low and the curvature distribution clean.
Fig. 3 — Stations and guide curves
The stations are copies of the same basic section, remapped to the local guide envelope as they move along X. The plan view tells me the width at each X, but not the height at which maximum width occurs, so I optionally use a separate side-view curve to define that height. Otherwise it defaults to halfway between the upper and lower profiles.
Fig. 4 — Introducing a shoulder
This is the part I’m particularly interested in your view on. If I need an extra control to introduce a gradual shoulder, I add the corresponding control to all sections so they remain compatible, but only move it on the stations where the shoulder is developing.
Fig. 5 — Zebra on the resulting loft
Although the section joins are G2, Zebra shows a subtle longitudinal feature along the Top, maximum-width and Bottom loci, particularly at maximum width.
A few questions:
  1. Does the basic four-segment station construction look sensible for this kind of loft, or would you strongly prefer each complete section to be a single NURBS curve?
  2. Is copying a section, remapping it to the new guide envelope, and then reshaping the copy essentially the workflow you meant by editing one master section?
  3. For something like the shoulder in Fig. 4, is progressively moving corresponding controls through several stations a reasonable way to keep it within the main fuselage loft, or would you regard that sort of feature as a point where separate surfacing becomes preferable?
  4. Does the separate longitudinal guide for the height of maximum width seem like a sensible way to define the sections from orthographic references, or would you normally establish that locus differently?
  5. Finally, would the Zebra feature in Fig. 5 concern you even though the section joins are G2? In this construction the curvature falls to zero at the Top/Bottom/max-width joins (see Fig. 2). I’m wondering whether the continuity is technically fine but the curvature distribution itself is creating the visible line.
The end goal is a fair RC jet fuselage with simple, controllable NURBS geometry, rather than trying to force every aircraft feature into one loft.
Thanks again — any criticism of the approach would be appreciated.
Have you seen the tutorial on the learn page for product design?
Here is one: Welcome to Freeform Modeling In Rhino
Is this your own design, or are you trying to replicate an existing design?
Why is the curvature zero at the top, bottom and max width? It does not need to be zero for curvature continuity - the curvature (and position and tangency) just needs to match.
A single degree 3 curve will have natural C2 continuity.
See Fig. 2 - you are introducing a flat spot top and bottom when aligning CVs G2 across a centre line. You always need G1 there (unless the flat spot is intentional).
