Sometimes when I loft 2 curves (deg3/10), the surface (deg3/10, deg1/2) control points match the curve input. Other times the surface has the same control points (deg3/10, deg1/2), but the position of the points are skewed.
Hi Eric - with ‘Do not simplify’, I think I’d expect the surface point locations to match the input curves assuming these match each other - can you post the examples you have in the image?
Non-uniform curves in the skewy version… so the curves do not actually match in structure. MakeUniform on the curves will fix it, but it changes the curve shapes, sometimes a lot, sometimes a little.
