Problem with Loft between curves
I have not been able to create the desired loft between two curves. My objective is to smoothly loft between the lower and upper curves so as to match the upper surface. Please help.
Loft Help.3dm (35.2 KB)
Hi Ronald - the seam points and directions of the curves need to match up. You cat to drag those around, with Object snaps, as well as flip the directions, during the Loft process with closed curves.
