Hi, i have a problem with loft
Invalid profile curve in loft, this may cause problems and Loft could not be constructed.
circular voronoi landscape.gh (23.3 KB)
Do you know how to solve it?
It pairs the corresponding lines before joining them (it is important to have identical paths for both).
It is an essential knowledge about the data trees.
sorry i’m not used to with grasshopper, could you tell me the script from the beginning? or the keywords for those
Your JOIN CURVES node is connected wrong. ‘P’ input isn’t for curves - read the help associated with each node.
Must either hold SHIFT and connect both wires:
Or use a MERGE node:
