I am having a loft issue. The system was working but after I re-edit the surface the loft had started to fail.
Null profile curve was removed
Invalid profile curve in loft, this may cause problems.
These are the warnings. I don’t know what to do. Can somebody help please
Quan_Li
(Quan Li)
May 24, 2023, 12:58am
2
230524_voronoi.gh (15.6 KB)
Thank you for the warning. It slipped my mind.
And internalize the geometry !
When a component throws an errror the first thing you need to do is to read the message - you did, good.
This indicates a null/invalid profile.
Searching though it and finding it at branch index {52;1} this shows a single line segment in the intersection.
So essentially the intersection does not work on the sides… Will experiment more because right now I can’t make it work properly.
You could simply remove those with Clean Tree but there will be holes in your pattern so… not ideal.
There we go. But it’s not a polyline anymore…
And theeeere we go with more sorting.
230524_voronoi.gh (15.9 KB)
Thank you so so much. It worked.
