Loft not smooth
In my attach file and picture, I using loft command but the object not smoot and how I convert this object to solid object?
Thanks All
Loft.3dm (4.8 MB)
Hello - I think Iā€™d split up the curves and make it from multiple lofts, like so:
Loft_PG.3dm (130.9 KB)
Thank you so much, it look good. From you model how I can make solid object?
Thanks
Is your cross section planar surface? Then you can use
Cap command to cap both opennings
