Loft a simple subD plane for a cushion shape
Hello-
Can’t seem to perform this sweep to create a cushion shape. I’d like to sweep a SubD plane around the quarter radius rails to create a quarter radius cushion.
Been doing my due diligence with tutorials but still coming up short. Tried using the existing faces / edges of adjascent cushions, tried making new edges / faces. Tried leaving shape open on one face as that’s what seems like the tutorials show https://docs.mcneel.com/rhino/7/help/en-us/commands/sweep2.htm
cushions.3dm (3.9 MB)
Any advice much appreciated,
best,
Revel
Hi Revel, try:
  1. DupBorder on one of the flar vertical faces marking the end of the arc cushion.
  2. Revolve >SubD output, 10 sections on the center of the arc, 90 degrees.
  3. Rotate a copy of the first vertical subD the same 90 because the other one does not quite line up as far as I can see.
  4. Join all three
  5. RemoveCrease around the hard edges.
example Sweep2:
1
thanks guys. I still cannot get the subD sweep to work, but I did have success with the revolve.
Question, why the shape can not be closed (grey out) ?
Going to try this one too, for a project
