Seems this is a Bug in Seregeti since Nov. 2017
wHello - as far as I can see this works here in the latest. What build (service release) are you running?
will update. Thank you @pascal
Will not color curves in Rhino V6 latest build. Is there any new settings to grey out the curves as all surfaces and polysurfaces. My default color for curves is blue.
Thank you!
Now I find that once in a while the locked object colors just fail and the viewports have to be reset(repeatedly using 4View) to get them back. Is this possibly the same thing?
@JimCarruthers doesn’t work on my side. but seems to be the default layer. thanks mate!
Hm - So far I cannot get this to fail - @JimCarruthers - does it fall apart after Rhino’s been open a while, do you think?
@hannesgrebin - can you please post the results from the SystemInfo
command in Rhino?
@pascal sure
Rhino 6 SR13 2019-2-27 (Rhino 6, 6.13.19058.371, Git hash:master @ 17cd8b51accbe17dd04b48028f49d5e77a67f17b)
License type: Commercial, build 2019-02-27
License details: Cloud Zoo. In use by: Hannes Grebin ()
Windows 10.0 SR0.0 or greater (Physical RAM: 16Gb)
Machine name: DESKTOP-A4MEI59
Non-hybrid graphics.
Primary display and OpenGL: AMD Radeon R9 M370X (AMD) Memory: 2GB, Driver date: 6-28-2018 (M-D-Y). OpenGL Ver: 4.5.13521 Compatibility Profile Context 24.20.11016.9001
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.5
Shading Language: 4.50
Driver Date: 6-28-2018
Driver Version: 24.20.11016.9001
Z-Buffer depth: 24 bits
Total Video Memory: 2 GB
Rhino plugins
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands” 6.13.19058.371
C:\Program Files\Rhino 6\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 6\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 6\Plug-ins\export_ACAD.rhp “AutoCAD file export : export_ACAD”
C:\Program Files\Rhino 6\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Users\grebi\AppData\Roaming\McNeel\Rhinoceros\6.0\Plug-ins\KeyShot7RhinoPlugin (486807a0-d332-4669-8086-e0497d91acd5)\1.6.0.0\KeyShot7RhinoPlugin\Rhino 5.0\KeyShot7RhinoPlugin.rhp “KeyShot7RhinoPlugin” 1.6.0.0
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 6.13.19058.371
C:\Users\grebi\AppData\Roaming\McNeel\Rhinoceros\6.0\Plug-ins\KeyShot8RhinoPlugin (6c7d7caf-b4ba-406d-bfaa-8d719d8212c3)\1.0.0.0\KeyShot8RhinoPlugin\Rhino 5.0\KeyShot8RhinoPlugin.rhp “KeyShot8RhinoPlugin” 1.0.0.0
C:\Program Files\Rhino 6\Plug-ins\Alerter.rhp “Alerter”
C:\Program Files\Rhino 6\Plug-ins\export_STEP.rhp “STEP Export”
C:\Program Files\Rhino 6\Plug-ins\export_IGES.rhp “IGES Export Plug-in” 7.0.19050.13065
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles” 6.13.19058.371
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 6.13.19058.371
C:\Program Files\Rhino 6\Plug-ins\export_PDF.rhp “PDF Export” 6.13.19058.371
Hi Hannes - thanks - nothing leaps out at me - the video drivers are getting a bit old, as these things go, so I’d update (Panels menu > Notifications > double-click on the notification about the driver and follow along to get the new drivers)
To recap and have it all in one place… if you set a specific color for locked objects in a display mode, locked curves do not pay attention to this, correct? Do other objects pay attention?
Yes, after a while, looks like it just happened now. Seems to happen on a per-viewport basis. Systeminfo:
Rhino 6 SR14 2019-4-16 (Rhino 6, 6.14.19106.18421, Git hash:master @ f05ebc98a63bb79de33e0ba2cafc4fe30ca8cf4d)
License type: Not For Resale Lab, build 2019-04-16
License details: Cloud Zoo. In use by: James Carruthers ()
Windows 10.0 SR0.0 or greater (Physical RAM: 32Gb)
Machine name: RAYNOR
Primary display and OpenGL: NVIDIA GeForce GTX 1080 Ti (NVidia) Memory: 11GB, Driver date: 4-9-2019 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 425.31
Secondary graphics devices.
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 4-9-2019
Driver Version: 25.21.14.2531
Total Video Memory: 11 GB
Rhino plugins
C:\Program Files\Rhino 6\Plug-ins\SolidTools.rhp “SolidTools”
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands” 6.14.19106.18421
C:\Program Files\Bongo 2.0 (64-bit)\Rhino6\Bongo.20.rhp “Bongo 2.0”
C:\Program Files\Rhino 6\Plug-ins\RPC.rhp “RPC”
C:\Program Files\Rhino 6\Plug-ins\RhinoBonusTools.rhp “Rhino Bonus Tools”
C:\Program Files\Rhino 6\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 6\Plug-ins\export_OBJ.rhp “export_OBJ” 6.14.19106.18421
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 6.14.19106.18421
C:\Program Files\Brazil 2.0 for Rhino 6\Brazil.20.v60_x64.rhp “Brazil for Rhino”
C:\Program Files\Common Files\McNeel\Rhinoceros\6.0\Plug-ins\Iray (6ac73cf3-0a75-45a4-a5a1-89e40bc53c4b)\1.5.376.0\6\IrayRhino.Plugin.rhp “Iray” 1.5.376.0
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles” 6.14.19106.18421
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 6.14.19106.18421
C:\Program Files\Bongo 2.0 (64-bit)\BongoUI.20.v60.rhp “BongoUI20v60”
C:\Users\James Carruthers\AppData\Roaming\McNeel\Rhinoceros\6.0\Plug-ins\SectionTools (fbdb1d7f-8cfb-42c1-9858-87cb6315932c)\2018.9.26.937\SectionTools.rhp “SectionTools”
Here the same.
Lock command wont change locked layers to light grey as it was before. Its hard to understand and killer workflow.
