When enabling curve visibility in rendered view port options and setting a single color for curves different than the curves’ object color does NOT change the curve color in the view port.
This worked in V5.
-josh
This worked in V5.
-josh
Actually this seems to not work for all view port modes.
-josh
I cannot recreate that issue here. Could you run the RH6 command SystemInfo and paste the result here?
Rhino 6 SR2 2018-3-6 (Rhino 6, 6.2.18065.11031, Git hash:master @ cd4fa1dcdec31cb58baacef0855771173af7196f)
Windows 10.0 SR0.0 or greater (Physical RAM: 16Gb)
AMD Radeon Pro 460 (OpenGL ver:4.5.13476 Compatibility Profile Context 22.19.170.1536)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.5
Shading Language: 4.50
Driver Date: 7-20-2017
Driver Version: 22.19.170.1536
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands”
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI”
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles”
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars”
This bug is fixed with SR2.
Sorry for the late reply.
-josh
Hi Josh - can you please export your modified display mode (Options > View > Display modes > Export button) and attach it? Was this mode created in V6 or brought over from V5?
Also, it probably would not hurt to get the latest driver from the ATI website and install that.
thanks,
