I am not able to reproduce this on a first try at least - as soon as I lock, selection is lost - @petumatr can you send me that you’ve got that does this? I can imagine there is a detail missing from my test,.
One more issue with the same file, I don’t know if I should create new topic for that?
When the block sits in the default layer with all the properties of the object (colour, linetype etc.) set to ByParent, It does not reflect the changes made in the detail in Layouts. See the picture, shouldn’t the right curve ‘block’ be also blue? Or is this one of the weaknesses of the blocks?
@petumatr - thanks - the steps are what I understood… what I am missing is, how are you making the selection to move the should-be-locked object? Can you click on it and have that gumball show up?
Hello - yeah, on a mac - I cannot see how a selection is allowed of the locked block… it is not allowed here, with your file. If you open the file you posted and click on one of the locked objects, do you get a selection?
Ok this is weird. I tried to reopen the file I sent you and the block behaves as it should. So I tried to create a new ‘identical’ file and have the same problem. Even after saving and reopening the new file, I tried to restart and it does not help. I guess you cannot reproduce it with creating a new file on your mac…?
