Can you show me how to load/register commands inside a dependency (myCommands.dll) referenced in a Rhino plugin (MyPlugin.rhp)?
thank you.
jmv
thank you.
jmv
Thank you for your quick reply !!
The sample code is old and is based on an old API.
Some functions are now private or internal.
So I update the sample code here:
// In MyPlugins.rhp
using Rhino.PlugIns;
public class MyRhinoPlugin : PlugIn
protected override void CreateCommands ()
base.CreateCommands ();
foreach (var cmd in MyLib.CreateCommands ())
RegisterCommand (cmd);
// In referenced assembly MyLib.dll
using Rhino.Commands;
public static class MyLib
public static Command[] CreateCommands ()
return new [] { new MyCommandA (), new MyCommandB () };
public class MyCommandA : Command { ... }
public class MyCommandB : Command { ... }
